TwinTurbo.NET: Nissan 300ZX forum - Re: Brake fluid: ok to mix Motul?
zwzweston
on May 06, 2024 at 10:41 AM
posted by Mike@ZSpeed
on May 06, 2024 at 06:55 AM
I think sticking with the 5.1 would be your best bet — iirc you’re only supposed to add higher DOT to lower and not vice-versa.
Mike@ZSpeed
06:55:56 05/06/24
Re: Brake fluid: ok to mix Motul? -
zwzweston
10:41:23 05/06/24
Re: Re: Brake fluid: ok to mix Motul?
Mike@ZSpeed
10:49:47 05/06/24
Re: Re: Re: Brake fluid: ok to mix Motul?
zwzweston
12:00:22 05/07/24
The nomenclature is confusing and should be changed
ZXoltan
18:38:36 05/06/24
Since you don't know which fluid you used previously, I...
Mike (NoVA)
08:57:10 05/08/24
That's a nope for me homie. (n/m)
23:44:08 05/08/24
Don't recommend 5.1 in the Z32, it reacts with plastics and
23:49:51 05/08/24
Interesting. Any idea why? Both 4 & 5.1 are glycol-based.
ZXoltan
11:09:47 05/09/24
Eeww, gross.
Ted (92TT)
12:06:19 05/09/24
Whoah. Was unaware of that one. Good callout. (n/m)
Zeus
18:11:07 05/09/24
Interesting that nasty stuff was showing up outside ABS unit (n/m)
Polishzx
11:26:06 05/10/24
All the seals / orings on the ABS unit weeped. (n/m)
19:37:11 05/10/24
Any idea about how long it takes for this to happen? (n/m)
Mike@ZSpeed
20:22:09 05/18/24
Not sure - but I guess less than a year. (n/m)
21:25:54 05/19/24
ATE TYP 200 is another great option
Polishzx
11:23:49 05/10/24
Good stuff! Running that in my dd (Audi) & brakes are great
ZXoltan
16:06:35 05/10/24
I do that too. Still have 3 cans of blue. Why was it banned? (n/m)
Ted (92TT)
18:24:11 05/10/24
The dye was not DOT approved. (n/m)
19:35:44 05/10/24
